The system is set for any oil that meets the GM spec. for this vehicle.e2helper said:As you probably know the algorithm for oil life is not calibrated for synthetic. It is only done that way on vehicles that are recommended/required to use synthetic.
What he is saying is that the computer has no idea what type of oil you pour in. The OLS will read the same whether you use regular oil or synthetic. My guess is that the OLS reading only based on speed, temp, engine rpm, and duration.otcpharm said:The system is set for any oil that meets the GM spec. for this vehicle.
Synthetic oil meets (exceeds) the spec. so the system is indeed calibrated for synthetics.
That may have been the intended message, but the literal message was that the OLS isn't set up to "work properly" with synthetic oil. I was only responding to the latter - I agree with the former.G6~Mike said:What he is saying is that the computer has no idea what type of oil you pour in. The OLS will read the same whether you use regular oil or synthetic. My guess is that the OLS reading only based on speed, temp, engine rpm, and duration.
I would have changed my oil twice already in 8000 miles.DocWyeth said:Now you have me concerned! I have 43% left and over 8.000 miles since the last oil change. What is the problem with the Diver Inormation Center? I have also complained about the built in outside temp readings and the gas economy gauge being incorrect, and not just a little. (05 GT)
Wrong mate. The OLS is there to prevent people from wasting oil by changing it prematurely.G6~Mike said:The DIC OLS is just a reminder for those who don't even know the car takes oil and will warn them eventually that the car needs service.
This happens with everyone. My boss says it happens on his Saab too. Its especially inaccurate right when it's been sitting, I couldn't tell you why.DocWyeth said:I have also complained about the built in outside temp readings and the gas economy gauge being incorrect, and not just a little. (05 GT)
Lucius said:This happens with everyone. My boss says it happens on his Saab too. Its especially inaccurate right when it's been sitting, I couldn't tell you why.
I think the amount of sunlight shining on it is a factor. If I'm starting up in the garage it seems normal. One day after having it sit in a parking lot for several hours it told me it was like 94 degrees outside right when I started up. In reality it was really like in the 40s.
There will still probably be 85% of us here who will change their oil at certain intervals regardless of what the OLS says. I would never depend on the OLS. Look at the DocWyeth's situation for example. 8000 miles and still showing another 43% before the oil should be changed. Lets say at 14,000 miles it tells him to change his oil. IMHO, that is way to long to go between oil changes.TLS2000 said:Wrong mate. The OLS is there to prevent people from wasting oil by changing it prematurely.
5 degree's hotter or colder than ambient?DocWyeth said:I know about it sitting in the sun. Any thermometer will do that. The eng. say that within 5 min or a few miles it should be accurate. I have documented mine being off by 5 degrees after 20 min of driving. It happens more often in the sun than cloudy days. They replaced the sensor once. What gripes me is I drive by the dealership every day. I have pulled in to show them and they agree that it is wrong but can't work on it right then and there and then when I take it back they play stupid and say well today it tested ok.
As for the oil sensor, TLS was correct. Read the manual. I just noticed that the gas milage really dropped off so I am going to change it anyway. Not sure if the milage it oil related or gas reformulation related.
There are a bunch of guys with LS1 engines who ran Synthetic for given intervals.G6~Mike said:There will still probably be 85% of us here who will change their oil at certain intervals regardless of what the OLS says. I would never depend on the OLS. Look at the DocWyeth's situation for example. 8000 miles and still showing another 43% before the oil should be changed. Lets say at 14,000 miles it tells him to change his oil. IMHO, that is way to long to go between oil changes.
We use barrels of oil each year on our farm so changing the oil a little early doesn't mean much to me. I would rather extend the life of the engine than the life of the oil.
Haha, mines a lease I follow the OLS. It's been going about 8000 miles on each change.G6~Mike said:I would never depend on the OLS.
If I was leasing I would change mine less frequently toobigbengt67 said:Haha, mines a lease I follow the OLS. It's been going about 8000 miles on each change.
The point that I was trying to make is this:G6~Mike said:That may be the case with synthetic oil but the poster above doesn't appear to be running that.
My friend bought an used 280Z and didn't change the oil for 2 years. The car ran perfect but it doesn't mean the engine won't suffer from premature wear and tear.My sister did her 1st oil change @ 60k mileson her Sentra, and that car did fine.
