I have a 2005 g6 v6 sedan. I have factory fogs and my driver side Fog light stopped working. I pulled out the bulb and it didn't look burnt out. I bought a new bulb and replaced it. It's still not working. I checked the fuse box and the fuse is fine. Any suggestions, ideas?
· 2008 Sedan 3.5L V6
faulty wiring maybe, not sure why that would happen but that seems like the most likely thing.
You need to test the harness end with a volt meter. Determine if there is power there, and if not keep moving back until you find the break. I doubt it is a fuse or anything along those lines, as one side still works. Generally, the circuit is divised as fog lamps, not per side. Being so, if one side is working, that circuit is live. You just need to verify if you do or do not have power on that side and why.
