I had to replace my driver side headlight assembly. Once it was replaced only one headlight will work at a time (low beam). During the daytime the driver side headlight comes on and at night it switches to the passenger side headlight. What do you think? What should I try?
Thanks
Da.v3
sounds like something is off / crossed with the DRL - daytime running lights / the sensor that turns them on / off or something.
Discussion Starter · #5 ·
The wiring for the original headlight was faulty. The headlight would stop working and I would have to go in there are wiggle the wire until it can back on. Well eventually the wire came loose and I could not solder it back.
