2010 Pontiac with 2.4L Ecotec motor
Back in 2017 I had issues with my power steering and ESC failing at red lights and eventually while driving which I had posted about here: Power Steering / ESC Light Failed at Red Light
The solution was to replace/repair the wiring and install a new throttle body. I had zero issues for 3 years, and then I randomly got a P0013 code in 2020. I noticed my oil was low, so I got an oil change, and the code went away.
Now here in 2021 years later I am having the exact same issues. I have been getting the P0013 code randomly, it seems like every few days it comes on then goes away. The car has also stalled/died about 4-5 times now in the last month with the same issue, the power steering and ESC turn off, but if I restart the car it's fine.
I have researched P0013 and I see it's related to drops in voltage or irregular voltage at the cam shaft but I am not well versed with cars so I am not sure exactly how to proceed.
I found this thread: P0013 code help
Should I start with that and check things with a multimeter?
Another issue I have is since I live in AZ all my plastic tubing around my wires has cracked, it's all over the engine bay and 70% of the wires are just exposed. I am trying to wrap what I can with electrical tape but not sure if related. I don't see anything obvious as far as broken insulation or cut wires.
Could the aftermarket throttle body be the issue? I am sure those things don't last very long, so maybe 3-4 years is a normal lifespan?
Also I found this video, should I just try this first?
They replace the solenoids which looks simple enough, should I start here?
Discussion Starter #2
Are these the right parts for intake/exhaust? Should I check them first or just replace?
exhaust:
12628348 VALVE. Engine Camshaft.
VALVE,CM/SHF POSN ACTR EXH SOL. Required: 01For: A 2.4-0/U(LE9) (2009-2011) (2009 - 2011). For: A 2.4-B/P(LE5) (2006-2008) (2006 - 2008). $50.05
intake:
12628347 VALVE. Engine Camshaft.
VALVE,CM/SHF POSN ACTR INT SOL. Required: 01For: A 2.4-0/U(LE9) (2009-2011) (2009 - 2011). For: A 2.4-B/P(LE5) (2006-2008) (2006 - 2008). $50.46
