hey i tried painting my engine cover and battery cover the other day and the paint just bubbled up i was wondering what kind of paint u guys use?
I used Krylon Plastic Paint for my engine cover. I let it dry for about 8 hours before reinstalling. Any enamel or plastic paint that states it can be used in high temperature areas should be fine
I'll try that i used parts cleaner the last time... Gunna put the new crab intake in sat so ill try painting that again
Sent from my iPhone using Autoguide
Gotta make sure you scuff it, give the paint something to adhere to. You can use a scotch-brite pad, go over the entire thing. Then give it a good wipe with some surface cleaner to denatured alcohol, Once all prepped and dry. A good primer and paint, Like the others said a good paint designed for plastic should work just fine.
