1 - 1 of 1 Posts
i have a 05 g6 gt with the pano roof in it. it wasn't working so i got a whole used assembly from someone. the issue before was that the cable was broken and the roof wouldn't open...never had any leaks. i recently swapped out the assemblies. the new roof opens and closes fine, the seal seems to be good ad tight, i go no water between the panels, but when it rains i get heavy water in my headliner. when i come to a stop it will run down my windshield. i dropped the headliner and made sure all the drain tubes were hooked up.i'm not sure how the drainage system works for the unit but need to find where the water is getting in...today it was bad enough to soak thorugh the headliner. any suggestions? thanks
1 - 1 of 1 Posts
