So I bought a 2007 g6 gt sport package with a barley functioning parking brake, I thought okay ill buy some cables. Bought dorman cables, installed easily, the problem was that the parking brake applied and held perfectly but would not release, i used a pry bar and moved it by hand, I took the cables out again and measured them to make sure they went on the right sides, I thought well calipers are probably a little seized, replaced those and still the same thing!! when i pull the parking brake it pulls all the way up nicely the first time and then every time after it gets harder and harder to pull, the ratcheting mechanism works just fine
Did you ever come up with anything? I'm having the same problem with my 06 g6 gt that we just bought.
Many people with automatic transmission cars never use the parking brake, but the system used on the G6's is one that needs to be used periodically to keep it functioning. When I got my car, the brake lever would engage properly but the brake wouldn't hold the car. I kept applying it routinely and within a couple of weeks it gradually came back to full functionality. Of course this won't work if there's a mechanical failure that needs repair, but once it's corrected be sure to use it periodically. Mine had no rust or other mechanical issue, it just hadn't been used.
Well we wouldn't use it either but my son wants to use it to get his license later this week and it has to work. I bought a new caliper for the passenger side yesterday and it didn't work either. Didn't want to buy both if it wasn't going to fix it. So we pulled and released this silly thing a million times, bled the brakes real good and it never would engage:mad: So this morning I tear into the console and I'm going to look into the handle. I tear it all apart and can't find anything out of place so I'm going to pull the passenger rear wheel and have one more look around. For whatever reason I kind of kick the wheel and notice it didn't move, so I'm thinking i don't have it all the way off the ground. I look and low and behold there is daylight under the tire. I look and the handle is pulled up a little so I release it and the wheel spins, I pull up all the way and it stops the wheel. Damnedest thing I've ever seen. I cycled it several times and it worked like it's supposed to so I went ahead and put a new caliper on the driver side. I don't have any earthly idea why it wasn't working last night but it did this morning.
Just replaced the rear rotors and pads on my recently purchased G6. I did this because the E-brake was very weak. I found that whoever replaced the pad before me, failed to line up the tits of the caliper piston correctly so I only had E-brake functioning on one wheel. Rotors needed changing anyway.
I too would be interested in any solutions to this. Maybe it's the nature of the beast, and we never noticed until repairing something else? My similar scenario: 2009.5 G6, now with 221,000+ miles. Several years ago, left rear leaked at p brake lever shaft. I took it apart, found some corrosion and no repair parts for the area or worth the bother. 'Bought reman from O'Reily's. A year later, for some reason, I investigated and found lever shaft seized. They gave me another. Wondering about cables, I bought new, but originals I removed seemed to slide just as easily when removed. This year, p brake only worked a bit, on right side only. Found LS shaft seized again. They gave me another. Cable pulls freely, and its spring wants to retract it, when pulled by pliers. New assembly worked fine before assembly: its torsion coil spring snapped lever back to home. (Used cube tool to wind piston screw back home after bench play.) Assembled, initially looked promising. Now a week later after 2 or 3 uses, sure enough: inspection showed lever about an inch away from home bracket. All I had to do was reach up in there and pull it home with my finger. I too have wondered if repeat actuation on release would help parts go to home position. Does the darned thing need some kind of auxilliary compression coil spring in between the cable housing anchor bracket and the cable end bracket, to help cancel the normal cable friction plus the slack retraction spring, in the lever and cables system? It seems at least aftermarket return torsion springs are too weak or something. Meantime, I am still benefiting from fine performance and reliability from original right side assembly!
