Passenger Side CV Axle too short
1 reading
1.5K views 19 replies 5 participants last post by  rileymarkee00
#1 ·
2008 G6 3.5L V6
I ordered a GM8222 for my passenger side cv axle, however upon installation (sadly not before ) I found out it was shorter than the old one. The length of this part is 23 inches and I took to autozone and had them put it side by side with another new one, they were identical. They put in my VIN number and according to that, I had the correct part, but my old axle is longer and the one it’s supposed to take doesn’t fit ?
#16 ·
Thanks man. Currently using the old cv axle still. Yesterday I noticed after driving on the interstate at 75 mph for about 5 minutes, my car begins to make a loud ticking sound. I initially thought it was low oil pressure, so I slowed down and it continued to tick, ticked in neutral faster with the rpm’s, but as soon as I put it into park it stopped ticking. Engine oil level was fine, I drove it for hours that day, then I got back on the interstate and sure enough after 10 minutes it was ticking again. And didn’t stop ticking until I put it into park. Then it drove just fine after putting it into park. Wondering if it could be low transmission fluid? When I did try to use the short cv axle, I think I may have damaged the seal for where the axle goes in. Trying to find the part number for that and I’m gonna replace that and flush the trans fluid and go from there..
#18 ·
I don’t recommend flushing your tranny! Unless you’ve been doing it. Look this up for more info on why.
It’s better to just check your level and add fluid if it’s low. You can find a video on YouTube for this.
I ended up losing transmission fluid after my cv axle broke. It’s now leaking, so going to have to figure that out (seal?).
But depending on your transmission/year, there’s a bolt on the side of the pan, to check your level, passenger side by the cv axle
#17 ·
Same shit happened to me when I ordered my passenger side CV axle from auto zone and picked up in the store.
I argued with my brother who was installing it and said auto zone it's correct so it must be correct. So make it fit. He told me they are 2 different sizes but I demanded they are the correct part because auto zone said so LOL (stupid of me I know!)
Well my brother continued to install them and once finished. I left and no more than 3 seconds down the street my CV axle falls out of my transmission on me!! I couldn't shift my car into Park or anything! I had to use my Emergency Brake and my brother ended up getting it to where he was able to push my car back up the driveway and into the garage. He then put my old one back on till I was able to take my car to a shop. The shop told me to use genuine parts from NAPA instead of Auto Zone.
#20 ·
I think this car is coming to retirement. Few months back when I had the too short cv axle in, and it popped out, I’m afraid it did some internal damage to my transmission. I’m now getting a P0700 and P0751 , as well as no cruise control and the gears are sticking. It says shift solenoid A stuck off. I had tried adding some fluid last week. DEXRON VI, added 1 quart to top it off and checked fluid level. Before any codes came, I had also noticed a ticking noise at 70 mph+ that would disappear upon parking the vehicle.
