Hey guys I was wondering how much of a difference it would make if i replaced my stock chip, with an performance chip with for my 2007 pontiac g6 base sedan. I also plan on getting an cold air intake.
Which motor do you have, and what exactly do you mean by replace the stock chip with a performance chip.
If you mean getting a tuned PCM/TCM then get a WAMS and swap em out.
If you're looking at plug in chips like the jet performance chip, it's really not worth it. Although they may make a difference you're bound to run into problems with it down the road. It's not a really good long term solution. A tune however is perfect.
If you have the 4cyl and you put an intake on it you will need to get it tuned.
Chips? Absolutely none, it will only hurt you in the long run. What you want is a complete tune of your pcm/ecm. This is where you want to order from http://www.whiteautoandmedia.com/
If something seems too good to be true, it most likely is. My recomendation, start simple and rip out that resonator (it's free!) and get a new filter/CAI. Like Cruisin said though, if you have the 2.4L i4, you need a WAMs Tune.
