I have an 05 GT. I just put on an injen cold air intake, magnaflow exhaust, and obx headers. When I accelerate the engine shuts off. Does any1 know y this is happening?
Holy wow. To much work. This has to void the warranty! Becareful man!I have obx headers on my 05 Malibu LS with the 3.5L LX9. No issues and I'm running the Magnaflow catback from the G6 as well. The only problem is the CEL for the upstream and downstream O2 sensors having the same reading and complaining about cat efficiency with p0420 and p0430. I also put in an oil catch can (air filter for compressor), high flow intake, Monroe maxair shocks from 1990 Aerostar, Brembo rotors, Akebono ProAct ceramic pads, high flow intake, and it's running strong. Headers have been on for about 15K now. I'm working on O2 spacers using the HELP! spark plug defoulers and having them drilled out so my O2 sensors will fit on the downstream so I can fool the computer there's a cat.
So where you able to get the 02 sensor fixed?I have obx headers on my 05 Malibu LS with the 3.5L LX9. No issues and I'm running the Magnaflow catback from the G6 as well. The only problem is the CEL for the upstream and downstream O2 sensors having the same reading and complaining about cat efficiency with p0420 and p0430. I also put in an oil catch can (air filter for compressor), high flow intake, Monroe maxair shocks from 1990 Aerostar, Brembo rotors, Akebono ProAct ceramic pads, high flow intake, and it's running strong. Headers have been on for about 15K now. I'm working on O2 spacers using the HELP! spark plug defoulers and having them drilled out so my O2 sensors will fit on the downstream so I can fool the computer there's a cat.
