Super Moderator
It sounds like you are describing where the + and - are on the manual shift mode. If you shift from D to M, the shift leaver will move over to the left where you can push forward and backwards to shift gears up or down manually. The only time I have ever used it is to pull away in 2nd gear when there is ice or snow to keep the torque low and reduce wheel spin.
I never noticed it before! I did see that it is good for snow but zi have never used the manual shifting. Ty again. I'm having such electrical/wiring issues with this car!
