Only on the left side
Both low &high beers are out
Checked bulbs 馃憣
Checked fuses 馃憣
Marker & blinker works
Anyone want to buy a 2008 Pontiac G6 Gt hardtop convertible for $5.000.00
One of the most common problems of the G6 is for the connector to the headlamp bulb to arc causing it to melt/short out. Inspect the connectors for signs of it melting or burning up. If those conditions exist replace the connector with a high-quality ceramic one, not the cheap plastic kind or you will be doing this repair over again as it's bound to fail just as the original. A classic case of GM cutting a corner to save a few pennies with an inferior part.
Had the exact same problem, yes, it's the clip link that most likely failed. Mine ,on BOTH sides were full of rust and corrosion, went to a recycle yard and picked up the wire jigs and replaced both sides...problem solved. Mind you, don't forget to put some good quality dielectric grease in the clips to keep out moisture and you should be good.
