That tire pressure is way too high. It should be in the 30 to 33 psi range.rwbooth said:The Potenza's are rated to max 44 psi.
I filled mine up to 40 psi, seems to be pretty good.
What tire pressure is everyone running on the 18's?
You mean 225/50R18 right?mphred said:Goodyear, 205/50/18 is the size. The specs on the door plate say 30 PSI all around, so that's what I've been doing.
