I noticed when i start my gtp -after a few seconds i hear a sound--it sounds like the AC compressor turning on--the auto climate control is off -if this is it -it should only start when you turn the switch --to see i am going to pull the ac fuse to see if i still get the sound--let me know if anyone has noticed this
Designed For Action
Are you sure it's not the 'Active Air Intake' kicking in. The AC compressor does not start on its own. :confused:
have no idea-what is that? probably is -ac does not act on own as you say--you may have solved the noise--
Designed For Action
Actually, the 'Active Air' would come into play while driving. The more likely sources, are the fuel pump and the cam phaser(it controls the Variable Valve Timing). These are the things that you hear at startup. :cool:
thx guys
