Power window panel on the driver's side does not work. Rear windows do not work. The only other window that will work is the front passenger side window only from its own button. Power mirror adjustment on driver side panel works.
Can I rule out the power window fuse because the one window works?
If I try the fuse, how to change the 30A fuse. Tried for few minutes to get it out without success.
Any advice or previous experience with this greatly appreciated.
Thanks.
Hey yeah it might be a bad connection to the driver side window buttons.
While adding speakers i noticed what you described happened when i forgot to plug those switches into the harness. Might want to try checking the fuses anyways and if its not that remove the driver door switches and looking around there. I was suprised to see that not having those plugged in wood effect other windows from working but it did.
