Hi my tire has had a small leak for the past few months, so I took it to a place that patches tires. They removed the rim and from the back end you can see a big gash in the rim, must have hit a pot hole (lots up here in VT). I checked with a few places and the cheapest I can get a matching rim for is $150, so I checked craigs list and I found a nice set of GTO rims, all 4 for $200. Even comes with tires, allthough two of the four tires are bad.
They are 17" rims and appear to be the model 6570A.
Below is the specs:
bolt pattern- 5x120
width- 7
bolts- 5
How do I find out my bolt pattern size so I can see if these will fit? I have a G6 (2006) with 4 cyl.
Our bolt pattern is 5x110. You would need an adapter. It's better off just finding different rims.
Take a picture of your stock rim and maybe we can help you find a rim.
