Im going to be changing my own break pads. ( done it before on other cars )
What type of bolt is it to get the calipers off and what size is it?
Any help would be great thanks!
- jimmy
Lifetime Member
As far as tools go, just make sure you have a set of metric sockets (13-15mm) and a long handled ratchet for the caliper bracket bolts. I dont think I spent much more than an hour changing all four. Also be sure to buy lube for the caliper pins. Most all of mine were dry which tells me they didn't lube them at the factory :(
If you have a question like this again you can try to looking under the "search" and type in the key word. For this case I typed in "brakes". Not that I mind helping, you may find it faster. Good luck!!
Interesting, what is this "search" that you speak of?
j/k
last time i used it i had to wipe off a few dust bunnies. LOL
