Car 2006 Pontiac G6 2.4l base model sedan. I just have a few questions if I could switch out my 2006 radio with one from 2008 that has an aux input so I don't have to use a cheap Bluetooth adapter. Is their any sort of form that I would haft to replace the wiring harness or would it be as simple as remove and install? or would it be possible at all.
Thanks
Sincerely Csn_1976
I swapped an '08 radio into my' 07 and it was a simple change. I'll bet it would be the same for your '06. You'll need to swap "base radio" for "base radio" (not the Monsoon). The only complexity is that you'll have to reset the replacement radio using a "Tech II" compatible scanner or have (meaning: pay) a dealer to do it. This is because the radios "learn" the VIN of the vehicle they're first installed in and won't work in another vehicle until they're reset. There are even YouTube videos on how to swap the G6 radios.
