My cd player doesn't work so I was wondering if I could get a new one or
If I have to get a factory one because it shows the low fuel and door ajar and such will a store baught radio do that too
Colon Fire & Rescue
To keep your DIC you won't be able to put an aftermarket receiver in. If you don't care about loosing your DIC pop a double DIN into the slot and your good to go. Just make sure all your settings are the way you want them before you remove the DIC. All the info is stored after you remove the original unit. I have seen threads that people have moved the DIC into the glove box or center council
