I currently have my subs running with the stock radio but it took alot of cussing and rigging to get them going. I had to splice the rear speaker wires and hook an adapter to them to get the RCAs hooked up. I then had to take apart the driver side kickplate, find a green wire, in the mess of wires located there, expose it, and connect my remote wire to it. The rest is fairly simple. Run your power wire up through the driver firewall and connect it to the battery. As long as everything is hooked up on your amp, you should have bass. There is a post somewhere on here that gives you pictures and better instructions. I'll try to find it for you.
