Wondering if anyone has fixed rear camber problems with their G6. I have a 2006 G6 that I took in for an alignment yesterday. Maxed out rear camber adjustment at -3.6. Has anyone installed new camber bolts in the rear and fixed the problem and where are the rear camber bolts located?
The lower control arms in the rear, and toe links have camber bolts with offset washers to adjust camber.
A user on the forums made a kit to gain more adjustment, which did work for my car. But as far as I know no more are available.
I did find rear camber bolts for the G6 from Rock Auto. And it seems as if they're designed to get more adjustment than factory, but I haven't tried them specifically, at least they aren't expensive.
