I couple weeks ago I noticed a bit of a rattle coming from the rear deck in my 06 GTP. At first I thought one of my speakers was blown but the rattle got continually worse and now it's become unbearable to listen to music. Every time the slightest bit of bass hits, it rattles. I think that it's the brake light inside that's rattling but I can't seem to pinpoint it. Has anyone else had this problem? If so, do you have a solution?
yeah i had the problem.. and it was the speakers ... i replaced both my 6X9's in the back.... honestly there's not in that back deck to really rattle... maybe a loose screw or something ? to really find out i would start by trying to figure out exactly where the noise is first but more than likely a blow speaker .. the factory speakers suck in the G6's
I couple weeks ago I noticed a bit of a rattle coming from the rear deck in my 06 GTP. At first I thought one of my speakers was blown but the rattle got continually worse and now it's become unbearable to listen to music. Every time the slightest bit of base hits, it rattles. I think that it's the brake light inside that's rattling but I can't seem to pinpoint it. Has anyone else had this problem? If so, do you have a solution?
check to make sure its not the cables used to release the back seats so that you can fold them down, mine rattled like a beotch after I replaced my 6x9's and installed a 10" sub. the 6x9's can rattle because they are in a cheap plastic bracket that snaps into the metal below the rear window. i used a thin foam to put between the two pieces to fix that.
