How do you remove them so you can put new 6X9's in??
Mobile Audio Specialist
Remove the trunk liner, Should be clips everywhere, next take the back seat out, to remove it first pull out the bottom cushion (that part you sit on) Just pull up on it in the middle. This will expose your lower seat frame, than remove the bolts from the back (the part where your back goes) and unbolt and remove it.
Next pull back the weather stripping from around the rear A-pillars, then pull them out there might be screws in there I can't remember from memory if you look closely you should find it, if not they should just pull out.
Then back to the trunk look under the rear deck and you should see little clips in there, which hold the rear deck cover on. Push them in and through the holes then go back in the car and pull it off. And UN screw the speakers :)
If you are not mechanily inclined I would not attempt it.
Mobile Audio Systems By Marc
http://marcmobileaudio.webs.com/
