2009 Pontiac g6
RR door
My door lock actuator has failed and I'm trying to replace it but don't want to brake door trim panel. Can somebody tell were the clips and screws are?
Thanks
dman
rear door: pry off interior door handle cover, remove screws under cover. pry up window switch and disconnect wiring. not sure if there are push-pin fasteners on the rear edge of the door, if there are simply push in the center and pry out. then just pry around the edges of the actual door trim panel to pop any clips fastening it in out.
