I own a 2005 GT and I have worn out 4 tires on the right rear. Two were replaced by the dealer under warranty and each time I was told that the alignment was to spec. With my newest tire beginning to show the same wear pattern I took it to an independent alignment service. The owner told me that the spec for the G6 is for negative camber on the rear wheels with a slight toe-in. This would correspond to the wear pattern that I am experiencing.
Has anyone had a similar problem? I wonder if resetting the car to 0 degrees camber with an average load (slightly more than 1/2 tank of fuel) and no toe in will eliminate the problem.
Any suggestions would be appreciated.
