my remote start does not unlock doors. only occasionally if I hold the button in will it unlock the door. both remotes do the same thing. new batteries are in both units.
So you the mean the keyfob isn't working?
Its a common problem. You can get replacement button pads on eBay for like 5 bucks.
Or you can get the keyless fix which is a plastic insert with metal tabs to do the actual button work.
Olefart
Both mine and my wife's key fob's quit working and I took them apart and found the solder connections where the battery holder is soldered to the PC board were broke lose. Re-soldered the connections and been working fine ever since.
