Replace BCM on 08 GXP
My dealer told me I need a new BCM to correct some dash problems I'm having, my question is if I buy one off ebay ($85.00) and assuming it is a good unit will it be a plug and play? Never have messed with any of the new computers.
Professional geek
It would be plug and play mechanically and electrically if you match up the part numbers. You would still need to visit a dealer to have it reprogrammed after the swap. The BCM is responsible for all the security, including matching the keys to the values that are stored. In short, the car would start but would quickly stop due to not having a matching key code. If you had a key from the donor car and cut a blank without the transponder, you would be able to reprogram the BCM yourself to match your keys.
Other stuff like resetting the VIN so your radio would work and programming it so your keyless entry (and start, if equipped) will work require a Tech II programmer.
Figure on a $50 to $150 charge from the stealership for the above. Also figure you'd have to have the car towed in. Use that to see how much (or little) money you will save by doing part of the work yourself.
~ MattInSoCal
Breaks Stuff
Figure on a $50 to $150 charge from the stealership for the above. Also figure you'd have to have the car towed in. Use that to see how much (or little) money you will save by doing part of the work yourself. So if the unit is NEW (which would be doubtful on ebay for $85 but you never know) you'll be fine, if its used you are hosed.
~ MattInSoCal
Just to set the record straight, the BCM used in the G6/Malibu/Cobalt etc. is a ONE SHOT unit. It programs to the vin and locks completely and cant be reprogrammed. Why you ask? Simple, not only is the VIN in there but the Odometer is as well.
