I have a 2005 GT with the monsoon system. What is the trick to removing the plastic cover that goes over the tweeter? I can't seem to pull it off and I don't want to break it.
Thanks
Bill
well the first thing you have to do is take off the door panel to get to the tweeters. I seen it done to my 6 at Best Buy.
Thank you for the reply. I was afraid of that. I found out how to unclip the plastic cover over the tweeter, however it did look like the door panel had to come off too.
yeah the same clip thats over the tweeter is around the door so pull those towards you then, lift straight up cause there is a lip on the window sill. really easy though. Then the tweeter is held on by 3 tabs. Also there is a little pin by the door above where it looks on the side. And the star shaped bolts. Holding the door on.
Hope thats not to confusing.
