Unfortunately I had the same issue. I had to go to the Junk yard and cut out the Pigtail and reconnect all the wires. Good thing is make sure you cut the Driver side head light pigtail. All the wires are color coated so it would be easy to reconnect to the correct wires. Also use Dielectric grease on the replacement connector to prevent future corrosion. Hope this helps.
