1 - 12 of 12 Posts
Would anyone be so kind as to post some instructions for replacing the two rear 6x9 speakers on a G6 GTP coupe? I just bought some Rockford Fosgate Punch 6x9's and it doesnt look like the factory speaker setup is very user friendly. Any help would be most appreciated!
Rear speaker removal is easier if you don't have side curtain airbags. You have to remove the frame for the rear seat backs and remove the trim on the rear pillars. After you do that the deck will come out. I probably spent 3 hours on mine. My speakers didn't fit the plastic that the OEM's were in so I had to file them down until they fit.
GTPGuy82 said:
I got as far as removing all the bolts and the seats, and for the life of me I couldn't get the deck out. It kept hitting the rear window and there was no room to get it out.
You must remove the trim around the rear posts and even then its a pretty tight fit if you have head curtain airbags. I would never do it again unless I had to replace a blown speaker. The worst part about the whole process was having my face about 6 inches from the airbag while prying the deck past all the sensors and gas chamber for the airbags. :(
Discussion Starter · #9 ·
I did it!
I replaced the rear speakers. You have to take the real pillar trim off and then its quite easy. Except that it's a little cramped in the back of a coupe.
Still there's more work to be done (custom deck with amp, etc) but its not too terrible if you have the space to pull it all out and a good source of light.
G6 GTP now with Rockford Fosgate P1694C punch speakers.
We'll see how this one evolves.
I had just bought my G6 /6 cd changer w/6 speakers...Thinking 'bout changing out the rear speakers.Is this going to sound better or am I better off not doing it at all.It really doesn't seem to have any brillance or clarity to the stereo.I'm just wondering if I invest in new rear speakers if it will help?
I did it!
Can you tell a difference with the stock stereo and the new speakers?
1 - 12 of 12 Posts
