So I am in need of a new intake valve so my plan was to replace them all. Has anyone pulled the heads on the (I believe 3.6) vvt motor? It's a 2007 gtp gxp. Is there anything different on these that I should know before diving in?
check your messages, just replied back and then saw this but ya, beter plan on having your engine out of your car because its a DOHC engine, no pushrods so you have to take all the acessoris off the whole front cover the timing chains etc..... for what you will have to do to replace the valves you might as well rebuild the whole thing will you have it out, new bearings, rings etc
