Gentlemen,
I got a question, were do I install this black square that is attached to these wires on the Revotech "Eagle Eye" headlights?
Do I use the 3M sticky to attach to the headlights someplace, or do I stick it to the car someplace? I just don't think sticking it to the car is such a wonderful idea in-case I ever have to remove them, just the question is, exactly were do I stick this black box? ....The bottom of the headlights aren't the most spacious for a oversize box.
Anyone that has them, can you express your input.
Thank You!
Da.v3
yea the m3 is on it for a reason...
i put mine on the bottom of the headlight....
Gentlemen,
Thank You!
Theres actually tons of space underneath the headlights
I'm having a hard time finding the right height for the headlights. I'm not sure if its suppose to be like 3 feet above the pavement or 4 feet, the lights I mean.
I used a Allen wrench to move them up and down. but I'm also curious, are they suppose to look like a erector set with the lights shinning on a wall? they don't seem like a straight flat line.
I've also noticed they are very wide-panning lights over the default one, is this normal?
is there like a tool or method to figure out how to set them to the correct height?
The cut off is not completely flat but mostly flat.
Yes they are wide panning.
There definitely is a tool. It's called google. First link of "how to aim projector headlights" will tell you how to do it.
