Owner before me hit a pole and it messed the fender above the rear wheel up pretty bad. And the rocker pannel on that same side is crushed. How do I remove and replace?
The front fenders, trunk and doers are bolt on, all other sheet metal is spot welded to chassis.
You would have to cut off the offended panel, weld on new, fill and paint.
Now if this was a Saturn, those were cool in that every panel was bolted on!
