I've been looking for new rotors and brakes and have noticed that the 08 GT rotors are a different size then the Base model V6. If I were to buy rotors that fit the GT would they work on my base model with the stock caliper?
So even though it says gt and gxp models only I should be okay with getting them or do I need to find a different rotor? I have a 08 G6 with the base 3.5. I have traction control but Idk about abs but I'm sure I have it if I have tc
They are not interchangeable. If you have TC it is most likely you also have ABS so you will need the bigger ABS rotors.
