2007 g6 3.5 4D
So I've read through pages of this and seen people with similar issues but no answer.
There is a cyclical rubber squeaking noise coming from the front driver side. It isn't the breaks! It happens usually after a left turn and only at speeds under 40 km/h. It definitely follows the turning of the tires and not any engine belt.
Probably related is the steering wheel has a harder time (maybe 10% more) turning left than right but it's not noticeable unless you know the car well. It's also not the control arm or CV axle those have been checked.
I'm thinking it's some sort of alignment issue even though I had one less than a year ago but the steering wheel thing seems even more likely.
If anyone has anything even remotely similar please tell me what you did and what was the cause since I'm at a loss here.
