1 - 10 of 10 Posts
I am currently in the process of replacing the entire sound system in my 08 G6. I've gotten the new deck in with the metra replacement and I've gotten almost all my speaker wires ran, however today i ran into a problem. I cannot figure out how to get the wire into the door of the car. If anyone has a solution for this it would be very greatly appreciated.
Tim.
2006 Black G6 GT
Tim.
There is a rubber gromit in the door. Its hard to fit wires throught, but once you get it through, its cake to wire the speakers.
Discussion Starter · #3 · (Edited)
I had the grommet off and where it connects to the body of the car it looked like it connected into some sort of wire distributor that was the size of the grommet, is that not so? or is there a place to slip the wire through?
Mobile Audio Specialist
Drill a hole through plastic molex(BE VERY CAREFUL) , OR, use the factory speaker wire from the door into the car.O rif your in North IL bring it through!
2006 Black G6 GT
The gromet is the part attached to the car. You run the wire through there then you put it in a small hole (you make) in this stuff.
Then once you get it through this rubber stuff you can grab it through where you have removed the speaker.
Discussion Starter · #9 ·
thx. ill be trying this soon, its currently 19 degrees outside and unfortunately I don't own a garage so... my friend does though so im going to try to get in with him.
1 - 10 of 10 Posts
