im guessing you have them tails already installed but for everyone else its super simple i can post pics if anyone wants them but ill explain cause this took me literally over an hour to figure out how to install these bad boys, the insturctions that come with them are very VERY pathetic...
1. unbolt your stock tail light
2. once you have the tail light out disconect the harness from the car, remove ALL THE BULBS EXCEPT THE REVERSE LIGHT, just twist them off, REMEMBER WHERE YOUR REVERSE LIGHT BULB IS cause the reverse light on the led tails uses the same bulb not a led bulb...
3. once you have the harness all the way off the stock lights take all the bulbs out of the harness EXCEPT THE REVERSE LIGHT BULB
4. now your left with 1 bulb in the harness and 2 empty slots, this part is self explanitory you cant mess this part up cause the led tail connectors have 2 different connectors just plug the other 2 harness connectors in and put the reverse light bulb in the new tails install the connector to the car, bolt on and BAM you got yourself new led tails...
the reason this took me so long is cause i have never done led tails before so i had no idea you had to use your stock tail light harness and the insturctions dont say anywhere you had to use it...
ik this is only a how to but if any of you are thinking of getting these i definitly recommend these lights i have the smoked ones from sabersport and they are BRIGHT AS HELL...im not kidding i cant beleive how bright they really are.. they are very cool looking i would hate to be behind me on the road, NOT KIDDING....so far i love them, they fit perfect look great and are a very nice upgrade for 220$
if anyone needs pics let me know and i hope this helped
o and by the way i forgot to say that gold box is the resistor...the reason for the huge box is that the leds take more power to run than the regular stock bulbs without it you would blow fuses, and or they wouldnt turn on which is actually a major problem with these tails...luckily if anyone is reading this buy them from ebay from the company sabersport and you wont have ANY problems they put a nice BIG resistor on it, some companys dont put a big enough 1 and some ppl ik on the other forum (g6p) are having blow parking light fuses from the resistor not being big enough..
