hey gang newbie here.i just bought a 2005 pontiac g6 that was wrecked.i replaced the drivers air bag,passenger air bag,the drivers seatbelt had that reset along with air bag control module.the front 2 crash sensor were used of a car the didnt have the air bags blown.and a used clock spring that came of a car that the airbags didnt blow.the airbag light was still on so i brought it to the dealer to have reset,that didnt work somethingelse is wrong.could it be the passenger seatbelt even thow it still works good and nothing was wrong with it?like i said i had to replace the driver seabelt as it was broke from the accident and had to be fixed,but again the passenger work fine.im at a lose right now,so anyhelp would be soooooo greatfull.thanks
Im in the same deal like you, your airbag module needs to get reset, this will take off the airbag light from the dashboard and will erase the message from your radio if you have it on there. the dealer should be able to do it but you'll have to ask how much they'll charge. i know a guy here that does it himself for 100$ but i dont think you'd be around where i am now.
as i said in my first reply,i did have it reset but that wasent the problem,but anyway i found out that even thow the passenger seatbelt still worked,it still needed to be replaced,thats why the airbag light says on.so if anyone is doing this kind of a job,be aware that even thow no one sits in the seat for some dumb reason,you still have to replace it.the sad part of this is,the seatbelt works great,but the dealer told me that it send some kind of charge down to it and pops the air bag light on anyway.so i had to get another seatbelt,put it in and then bring it to the dealer to still remove code and that was it.
