1 - 18 of 18 Posts
Hello. My 2008 G6 recently had the information center display that my vehicle needed to have its Traction Control serviced. The brake light stay on all the time and the cruise control won't engage. Put it in the shop a couple times and had the brake sensor switch replaced as well as the brake control module. Does anyone have any wisdom to what might be wrong. I would appreciate some input. Thanks.
Sent from my iPhone using Autoguide
Cruise control probably wont work because the brake lights stay on, It's actually (stupidly) a common issue.
Start by disconnecting the battery.
Go to the passenger fuse box (In the center console passenger side)
And unplug the large plugs from the BCM.
Clean the connectors the best you can.
Apply Dielectric grease
Plug it all back in and reconnect the battery.
The brakes lights should work properly, and hopefully the cruise control would work now as well.
Here's a video that outlines those steps:
He doesn't disconnect the battery and doesn't actually clean the connectors in the video. Just applies the dielectric grease and puts it back together, Pretty sure they have repeat issues. If you clean it you should be fine. He also just does one connector. It wouldn't hurt to do the other one as well.
No problem. I forgot to mention, They sell a spray can Electronics Cleaner. You can buy that, give it a good spray and blow it dry with a can of compressed air. Unless it's a product that dries pretty quickly on it's own.
Cool. I'll add the to my list. Hope it work. Just got my G6 in February and I love it, except for these few things.
So I'm curious. Who replaced the BPP sensor & EBCM for this issue? Did they complete the BCM connector removal/reinstallation as specified by GM for this issue first?
I just noticed the guy in the video did not remove the correct connector. He pulled C1 but the culprit connector is C2 (marked J2 on the BCM) which is above C1 (marked J1 on the BCM) & facing sideways. That is the problem connector specified in the bulletin for the brake lamp issue. Since you are in there anyway I would just do both C1 & C2. What actually "cleans" the corrosion is the simple act of removing & reinstalling the connector a few times. The rubbing of the contacting surfaces together is essentially like using an abrasive. Then by spraying with electrical contact cleaner at least some of the corrosion is washed away. The layer of corrosion is so thin usually you can't even see it (unless you are really looking for it). But it's enough to increase the resistance across the metal contacting surfaces which results in the BCM getting a "false" signal.
Here's the bulletin:
Service Manual | Document ID: 2294853
#08-05-22-009A: Intermittently Brake Lights (Stop Lamps) Do Not Function Correctly, Extended Travel to Shift Out of Park, Cruise Control Inoperative, DTC C0161/C0277 Set (Perform Repair as Outlined) - (Jun 25, 2009)
Subject: Intermittently Brake Lights (Stop Lamps) Do Not Function Correctly, Extended Travel to Shift Out of Park, Cruise Control Inoperative, DTCs C0161/C0277 Set (Perform Repair as Outlined)
Models: 2004-2007 Chevrolet Malibu, Malibu Maxx
2008 Chevrolet Malibu Classic
2005-2009 Pontiac G6
2007-2009 Saturn AURA
This bulletin is being revised to shorten the required procedure and revise the Warranty Information. Please discard Corporate Bulletin Number 08-05-22-009 (Section 05 - Brakes).
Condition
Some customers may comment that intermittently the brake lights do not function correctly. Other symptoms may include extended pedal travel required to shift out of PARK, cruise control does not function correctly, and DTC C0161 and/or C0277 may be set.
Cause
The most likely cause of this condition is high resistance due to terminal fretting corrosion in the body control module (BCM) C2 connector (specifically pins C2-18, C2-31 and C2-59).
Correction
DO NOT replace the BCM for this condition. Disconnecting the C2 connector, adding dielectric lubricant and reconnecting the C2 connector per the procedure below will correct the high resistance condition due to terminal fretting corrosion.
Remove the right side front floor console side trim panel to access to the Body Control Module (BCM).
Locate the C2 connector on the BCM.
Unlatch the C2 connector and disconnect the C2 connector from the BCM.
Apply dielectric lubricant (clear gel) GM P/N 12377900 (in Canada, use P/N 10953529), or the equivalent, on the BCM C2 pins (apply with a one-inch nylon bristle brush) on all the C2 connector pins (this will treat the pins against fretting corrosion).
Reconnect the C2 connector back on the BCM and re-latch. Wipe away any access lubricant..
Reinstall the right side front floor console side trim panel.
Using the Tech 2®, check that the BPPS ratio is equal to BPPS learned home when the brake pedal is not depressed.
• If they are equal, brake lamps should be operating correctly and no further steps are necessary.
• If they are not equal, perform the Brake Pedal Position Sensor Calibration procedure in SI to complete the repair.
Check the brake lights for proper operation. If incorrect, refer to SI and perform normal diagnostics.
So I just reread (more carefully) the original post & I may have screwed up my answer. Are the brake lamps (including the top-mount lamp) lit constantly with the key on? So the brake pedal has no affect on the lamps? I need clarification.
I personally went with the 3oz tube so I could do ALL my electrical connectors, Just a preventative sort of thing. Unless you just plan to tend to the problem areas the small tube should suffice.
Discussion Starter #17
@greenman. Yes they replaced those two parts and nothing else. They didn't mention if the found any codes. My pop had a diagnostic code reader and we checked it together and it did not read out any codes.
A normal code reader will not read these codes. You need a proper scan tool & they are expensive. Most pro mechanics would have one. How about calling whomever did the part replacing & asking them which codes they found?
Whoever did the work is just throwing parts at it. Sounds like a dealer mechanic. I trust that they zeroed out the BPP sensor (necessary when it's replaced).
Since the BPP sensor & EBCM have been replaced, what's left is either a BPP sensor harness issue or a BCM issue.
1 - 18 of 18 Posts
