Alright, in trying to help another user solve some A/C lag problems I finally found the source of a noise I've heard since I bought the car. On a cold start, usually the first start of the day right after the engine kicks over you'll hear a kind of knock. I thought it was the engine shifting after start up but I've come to learn it's the A/C kicking off.
Here's a video that showed me this.
The A/C is at the very top, you can just barely see the pulley and clutch.
You'll see it's engaged when the engine starts, then it quickly disengages.
Then I turn it on so it re-engages.
I'm wondering should the A/C do that? I've had a host of A/C issues when I first bought the car and was assured it's repaired and in good working order...
Here's that video:
Also the entire climate control was OFF. Until I switched it on after the engine was running.
My compressor makes the same noise when I turn it off and on though I'm not sure about startup. I have the auto climate control and its hot out right now so the AC stays on when I start up. But I'll check after work and see how it goes.
Sent from my MB860 using AutoGuide.com App
I have the manual climate control. But If it's off it seems to be one while the engine starts and then quickly shut off, just seems odd..
Was raining when I left work but I'll check in the morning when its cool out.
Here is a much better video I shot today.
First start of the day, the clutch on the A/C seems to engage during cranking and as soon as the engine fires up it'll disengage.
Climate Control was OFF
Haven't been able to view your videos but the answer is no, the a/c clutch should not engage during engine cranking (or until the engine speed reaches 600 rpm for that matter).
Hmm, Now I wonder what could be causing it, It's not a sticky clutch, I'm leaning more towards something sending the signal to the clutch during start up. It's not every time though...
Discussion Starter #8
I've created a looped GIF from my video, It just cranks runs then restarts.
Seems to run a little fast, oh well
