21 - 30 of 30 Posts
rwbooth said:
miscreant,
I said "That may be true but not all G6 rims are interchangeable." Then you go a spread erronous info yourself. The base V6 WILL NOT FIT THE OVERSIZE BRAKES of the performace G6's (GT and GTP.) Hence the problem we are all having.
Quit restating info to make yourself seem like king shit - it's annoying and not welcome.
Check yourself, dude. Direct your anger of not having a solution to snow tires SOME WHERE ELSE. I SAID that the wheels probably won't fit on the GT/GTP, read my post again! So there's no erroneous info there. Said that GT/GTP wheels would fit on base V6s, but base V6s won't fit on GT/GTPs...From the start, I have given you as much correct info as I could, even when other people told you WRONG. The link about me saying the 16" may not fit on GT/GTPs was a response to YOU a couple days ago before you even tried this: (I quote)"However, Ive been unable to find confirmed results of putting 16" wheels on the GT or GTP. For instance, when you select a G6 Sedan on tirerack, it gives you 16" wheel options. However, selecting the G6 GT Sedan gives you only 17" and higher wheel options. The GT and GTP feature larger front brake rotors which may prevent certain (or all) 16" wheels from fitting. Either way, I can't get a straight call on that one."
You may have indicated above that they weren't interchangeable, but you did not indicate WHY, however you did post the following: "The GT and GTP are the same however the base and V6 aren't. Hence the problem, we can't take the 16's off a V6 and use them as snow on my car - they are different" - that sounds like you are saying the wheels are different bolt patterns, but it's not the wheels at all that are different, it's the brakes that are different. "the Sales Manager has been in touch with GM to tell them not to be so stupid in the future. Why would a line up of cars have different bolt patters? It seems to me that none of snow tire issues would be issues if they had used some foresight and made them all the same." I see now that the "line up of cars" was to mean GM's line up of cars, not the "G6 line up of cars" - the statement makes it sound like the problem was still the bolt pattern.
FWIW, Opel and Saab designed the epsilon platform. Opel and Saab have been 5x110mm bolt patterns for a long time. GM already has at least 6 different bolt patterns in their lineup, there's no standard (Ford has 5 that I know of, Chrysler probably as many). GM's intention is not for owners to put their own wheels on, GM has no reason to standardize bolt patterns.
However, the issue really is the brakes, which is a typical issue with more performance oriented brakes. Few steel wheels are available in 17" if any that I know of. If the GT/GTP brakes don't fit 16" steel wheels, then they don't fit 16" steel wheels regardless if the bolt pattern was 5x115mm or some other more common pattern - it's not an intentional thing that GM did.
I'm sorry the steel wheels didn't work out for you, but it's certainly not my fault and it's not GM's fault. It's the fact that you want to put steel wheels on a car that can't fit them because of the bigger, better brakes. I know it's a stretch, but I'm sure some Corvette owners would love to put steels on their car too, but I can assure you that they won't fit that car either, regardless of bolt pattern. I couldn't on my GTO, the brakes were too big. I couldn't on my CTS-V, again, the brakes were to big. Should we curse out GM for putting too big of brakes on these cars???
Just so I won't "repost it so I can sound all king shit" (whatever), I've posted my recommendation on cheap wheels before...
EDIT: If my costant posting of the "same information" is bothering you, I apologize, but it's not intended to be directed at you. Just because I quote our post does not mean I'm telling you the information all over again, but rather reiterating or even adjusting previous posts with the new information for everyone's benefit. Clarifying this information and getting to the bottom of what fits and what does not may not be "welcomed" by you, but I'm sure it's welcome by most.
So we have determined so far:
* that the 16" steel wheels from the G6 (and most likely from the Malibu or Saab 9-3) will not fit the GT or GTP models.
* Most likely the 16" aluminum wheels will not fit the GT/GTP as well, though as of yet that has not been exactly determined.
* The GT and GTP wheels will fit the base models (basically fit on all models), but the stock GTP tires are too tall and would need to be replaced or the PCM would need to be reprogrammed (GT tires are correct height).
........16 steel...16 alum...17 alum...18 alum..
4cyl...|....X....|....X....|....X....|....X**..|
6cyl...|....X....|....X....|....X....|....X**..|
GT.....|...no....|....X....|....X....|....X**..|
GTP....|...no....|....X....|....X....|....X....|
* Unknown but most likely not.
** Requires 1" shorter tires than stock, or PCM reprogram.
Discussion Starter · #24 ·
miscreant,
sorry about the last post - got a little carried away. To put this thing to bed:
If I go to tirerack and chose 05 GT (even though I have an 06 GTP) will the 17 alloy rims fit my car?
rwbooth said:
miscreant,
Yes, but don't use the tire recommendation size, they'd be too short. a 225/55R17 would be good.
"Ya'll" Don't take offense..but the first time I visited FT Cambell I about died laughing at the gas station when I heard someone say that for the first time. The accent + "Ya'll" Fricken priceless!!!!!!
After Market
I put some Dip Wheels, the Ninja 65's on my 06 GTP coupe. Looks awesome
Got them out the door on the car for 1400 buck Canadian. Figured it was better than paying 950 for GM to polish up a couple of spoke faces.
For the extra 550 , I now have 2 sets of nice looking rims summer/winter
Will post some pix once I get her wash :) ed
Winter Tires for 06 G6 GTP
So having read all of these posts back and forth (insert laugh). Can anyone just simplfy things even more clearly and just state precisely. What Size and make and (maybe even where) a Canadian in the GTA. Can get winter tires for a 2006 G6 GTP. That wouldn't need to have the speedometer reprogrammed. I do thank you in advance for your time and help in this matter.
21 - 30 of 30 Posts
