I don't know exactly how to describe it but when at idle the car itself will 'sputter' or 'shake' or 'shimmy'. It will only last for half a second or so and then its fine for another couple of minutes. At work I usually sit in the car on lunch and talk w my wife and smoke a cigarette and with it being so cold, I'd run the heat.
Turned off the heat, same thing. Today I noticed when I put the car into reverse it kinda grabbed a bit harder than usual - I have a 2009 with 65,000 miles - this normal and I'm just now noticing it or should there be maintenance on my side? I think a tranny flush is in order but again, not 100% sure.
Thank you in advance,
David
David
