I made the mistake of buying Spyder Headlights for my daughter's car. She is constantly complaining about the dim lights are not bright enough. Can someone recommend a brighter replacement bulb. One that doesn't require any modifications. I'm a female who is new to all this high tech. Auto Stuff.
not sure on the bulbs, but your best bet is probably be HID's which for the most part are plug and play. Eventhough Spyders don't have good projectors, you'll be a lot better off. If you do so Id suggest going with 5k in color, they will be a bright white.
....maybe someone else will chime in on the bulbs. Dom1nix usually has some good info.
