The G6 is my DD :-)
How does one "turn on" SC on a car without this option? SC (normally) uses the ABS sensors and computer, so I can't imagine that any extra components are needed, so is there a way to "install" SC on a car that didn't come with this from the factory?
Professional geek
The wiring is probably already in place, but you would need to add the accelerometer and yaw sensors and get a new BCM with the StabiliTrak software in it. It's not an add-on.
~ MattInSoCal
The G6 is my DD :-)
Discussion Starter · #5 ·
do you have traction control?
Yes. Based upon experience, I can't imaging that GM does not design SC to be anything more than a TC add-on during manufacture. I could add the necessary Yaw Sensor and update the BCM pretty easily. The issue would be having the correct harness under the dash.
