Car started having issues with stalling, it would sit for a bit and then start. Then it wouldn't start without being jumped but then would run, then it would start only with jumping but would die while driving and need to be jumped again. Then it went to had to be jumped but wouldn't stay running more than a minute or two.
Alternator tested good, we replaced the battery and code reader there a MAP sensor code so we replaced that. After putting in the new battery it started right up so we thought it was fixed but t next morning went to try to start and it just started clicking and the door locks were going haywire and it wouldn't start. Any ideas?
Super Moderator
Have you checked for bad grounds? If you take the jumper cables and connect battery ground to engine block and battery ground to chassis, does the problem go away (you will need to start with a charged battery)?
