Hello,
Does anyone have a diagram or pictures of the steering wheel radio control unit taken off the steering wheel itself?
I need to replace mine, and I don't want to break one while taking it off another car, nor break mine in case I keep it.
The volume up and down buttons do not work, but the station/cd track buttons do work. I was told $40 from the dealer to buy a new one, but think I can get one cheaper from a wrecker.
Thanks
Ok, I will be making a post about this, but here are some from an 07 Malibu and the cruise buttons from an 09.5 G6 on right:
Here they are mounted on one side:
and the other:
There is just one phillips head screw to remove and the panel just slides out towards the center with a little wiggling once the airbag is out of the way. The Horn relay plate can be removed to make it easier, but not necessary. It removes with 3 either T20 or T25 (probably T25) torx and unplug the connection.
Here is with the Horn Relay/Airbag mount in:
Hope that helps.
Discussion Starter · #4 ·
That's excellent, exactly what I was looking for.
Thanks so much :)
and the other:
Hope that helps.
