2006 Black G6 GT
So today i installed my car audio system. As far as i know i did everything right.
Soldered wires, used crimps and ends and connected all the right things.
The stereo works and sounds great, but whenever i'm driving and use my turn signal the radio turns off and then comes back on about 10 seconds later.
Anybody Ideas?
2006 Black G6 GT
Discussion Starter · #4 ·
I think i figured it out, not sure tho.
I called PAC and talked to tech support and said that i have to make a relay because the red wire could only take so much power or something.
So i bought a relay and have to do some weird stuff with it and the wires and see if that works. I hope it works!
Ill keep u guys updated.
CrAzY Moderator
prob told you to put the relay right after the battery if you just run wire it draws power causing something to turn off or draw less current without the relay
CrAzY Moderator
haha Kevin
