1 - 20 of 26 Posts
Where's the 'Thank' Button on this thing? Cause I'd like to thank waterfowler for this!:D Thanks man I deeply appreciate it!
i was wondering if anyone would have an answer i replaced 2 new rear speakers and there should only be 2 wires to connect and there was four, and also when set it on rear theres very little sound?????????
Discussion Starter · #7 ·
i did the exact same thing, and the speakers i put weren't nowhere as good as the stock monsoon ones.I had to change the 2 wires into different holes because like you said, there's 4 when the speakers i put in had 2, so i was just messing around with it. Very very confusing :S
Any fixes or workaround so that with the 2 wires i can like in a way merge the wires and make 2 out of the 4? I think im just being confusing but oh well maybe one of you guys understands me...
Administrator
yeah i understand but i think youll run into trouble because the four wires are coming out of the monsoon already so seeing that two are for mid range and two are for tweeters you really might be better off just using two of them depending on what speakers your installing.
Discussion Starter · #9 ·
Oh yeah that's what my uncle told me, he said that since there is 4 wires, you'll have to decide whether you want more bass or more treble since the new speakers only have 2 wires. But the stock monsoons are like 1000 times better than the new speakers i was about to install, so i stuck to my semi-blown monsoon speakers :)
FYI...I just came from the car audio store down the road....looking for bass and to upgrade the front stage.
Apparently you cannot just use standard speakers on this car. Pontiac used 2ohm speakers and if you buy the standard 4ohm you basically have half the output you did before. That might explain your loss of sound.
ZarkSniper, after months of online research and talking to several car audio stores, that's the most intelligent thing I've heard. Thank you. You just restarted my quest to get these things working again. Off to find 2 ohm speakers now.
The only 2 ohm speakers I've been able to find are from Infinity and JBL.
For future reference, I think the best thing to do is buy an adapter plate that will hold a 5.25" or 6.5" woofer and one tweeter in a 6x9 location. Then you can use all four wires. That's what I'm going to try next.
Sony Explode 6x9's are four ways, I have them in my car, yes you may have to slice into the wiring to get them to work properly but they will play just as loud if not louder when they are installed, I have them in my 08 G6 GT right now and I love them and the only costed me $40 for the pair and they are 460 watt max a piece.
1 - 20 of 26 Posts
