So when the bulb burns out.........by carefully removeing the gray trim ring, and poping out the clear lense. then apply a few drops of superglue to the small lip that the clear lense sets on. let dry and re-install. been there done that![]()
what are you getting at "when the bulb burns out" ? you cant replace the bulb by removeing the clear plastic lense, it only comes out from the inside. you have to take the whole gray trim ring off to replace the bulb and i did not say to glue that.......So when the bulb burns out.........
Wedge a Small piece of paper in there and it works beautifully
??? In my freinds 6 you just pop off the clear lens.....what are you getting at "when the bulb burns out" ? you cant replace the bulb by removeing the clear plastic lense, it only comes out from the inside. you have to take the whole gray trim ring off to replace the bulb and i did not say to glue that.......
hmm??? In my freinds 6 you just pop off the clear lens.....
