1 - 14 of 14 Posts
I have no clue how many coats to do/how many clear coats to do, and if i should sand it afterwards. Anybody have pics of theirs?
2 coats VHT niteshade, 3-4 coats of clear.
what type of clear did you guys use?
I bought my VHT in a kit and it came with a clear, I look later what that is..
Looks good. I finally decided to do a light smoke on my tails. But I'll be going with vinyl so It'll be easy to remove if I ever need to
Keep applying coats until you think its too dark. Then start wet sanding it with 1000 grit until its the darkness you want. How dark its going to be after each coat is going to depend alot on how thick your coats are and the prep work you do in between coats. You cant really base the darkness just off the number of coats put down. I have 3 on mine but they are as dark as mitch's. Apply your clear, wetsand it smooth with 2000 grit and polish/wax.
Between the first and second picture, it is the same paint, just one's inside and ones outside. And yes, that is will two coats of niteshade, and 3-4 of clear.
Discussion Starter #11
ok thanks. even though your clear came in a kit, what kind is it? your tail lights look great btw.
Dupli-ColorTM Clearcoat Aerosol Can. and thanks.
1 - 14 of 14 Posts
